SFTP server encryption at rest using .NET Assembly
Is the file encryption feature for SFTP servers enabled by default or exposed in the .NET Assembly in any way? If not, do I need to do my own encryption to get the same result? I've looked through the documentation but haven't found anywhere to specify an encryption key.
https://winscp.net/eng/docs/file_encryption
https://winscp.net/eng/docs/ui_login_encryption
