PowerShell – Find Files Method
wonderboom
England
in the UI I can use the "Find Files" function to recursively search subdirectories on a remote site for a file type using this file mask.
/*/dir1/dir2/*.csv>=7D
which all sits under
/blah
And from the resultant search results I can transfer all the files it finds in a single process, I've searched the forums and Googled this and can't find any method of doing this in PowerShell, does anyone have any pointers? Is this even possible?
I only want the files it finds, not the directory structures.
Thanks.
wonderboom
England
Tried the below PS
Just to update on this I've tried the code below.
$RemotePath = "/blah/"
$TransferOptions = New-Object WinSCP.TransferOptions
$TransferOptions.FileMask = "*/dir1/dir2/*>=7D"
$Wildcard = "*.csv"
$FileInfos =
    $Session.EnumerateRemoteFiles(
        $RemotePath, $Wildcard, [WinSCP.EnumerationOptions]::AllDirectories)
ForEach($File in $FileInfos){
    $FilePath = [WinSCP.RemotePath]::EscapeFileMask($File.FullName)
    $Session.GetFiles($FilePath, $LocalPath, $False, $TransferOptions) | Out-Null
But the GetFiles always returns False.
Any thoughts appreciated.
Re: Tried the below PS
What do you mean by "GetFiles always returns False"? GetFiles returns an object. It cannot return False.
wonderboom
England
Find Files
Martin,
Thanks for taking the time to reply, I've fixed the issue, it appears I had missed a \ in the local path which was leading to the issue with retrieval.
The code I'd pasted previously works for my requirement however I do have one question, can I apply the 7D filter to this section.
$FileInfos =
instead of just the *.csv wildcard, can I also filter this on days so I can then just retrieve all the files in $FileInfos rather than applying the FileMask and having to run through all the files discovered in the EnumerateRemoteFiles section?
Cheers.
Re: Find Files
No, as documented, the Session.EnumerateRemoteFiles supports only simple Windows wildcards.
https://winscp.net/eng/docs/library_session_enumerateremotefiles#mask
If your concern is performance, more efficient solution than calling Session.GetFiles with file mask is to query the RemoteFileInto.LastWriteTime.
https://winscp.net/eng/docs/library_remotefileinfo#lastwritetime
For an example, see:
Download files newer than X days from SFTP server with WinSCP, skipping folders that do not contain any matching files
