- Piscator
- 2
Couldn't agree a key host algorithm (available rsa-sha2-512, rsa-sha2-256)
I am using the latest version (5.19.6) and WinSCP is giving me this error. I use the key via Pageant (ssh-rsa 2048) and connecting via PuTTY (0.76.0.20220214) works fine. Suggestions?
Site Admin -
- 43,195
- Prague, Czechia
Re: Couldn't agree a key host algorithm (available rsa-sha2-512, rsa-sha2-256)
You will need to update to WinSCP 5.20.x beta:
Issue 1952 – Support rsa-sha2-256 and rsa-sha2-512 SSH public key algorithms
Thanks. That fixed the issue.
ebukaogbonna@...
I cannot upgrade
I am having the same issue with
ogbonnaebuka@...
Re: Cannot upgrade WinSCP
I am having the same issue with error text "Couldn't agree a host key algorithm (available: ecdsa-sha2-nistp256)". I am at version 5.7.7, but unfortunately I cannot upgrade as WinSCP is running on a remote Windows server which is not allowed to access the internet.
What would you advise in my case?
Thanks in advance.
Thanks in advance.
Site Admin -
@ogbonnaebuka: Well, you need to upgrade. There has to be a way to update software on the remote machine, right? Only other option to reconfigure your SFTP server to allow older deprecated algorithms (obviously, not a good solution).
joetsai
The problem is solved
It is just version.
Update to latest version can solve this.
- Sivakumar
- 1
Even in latest version same issue occurs
I am using WinSCP version 6.3.6, In this version also I am getting the "Couldn't agree a key host algorithm (available rsa-sha2-512, rsa-sha2-256)" issue.
Site Admin -
- 43,195
- Prague, Czechia
Re: Even in latest version same issue occurs
@Sivakumar: Please attach a full session log file showing the problem (using the latest version of WinSCP).
- steph_og
- 6
- Thailand
Also occurs in latest version 6.3.7
Any fix for this error as I am also encountering it in version 6.3.7
Thank you
Thank you
Site Admin -
Re: Also occurs in latest version 6.3.7
@steph_og: The log clearly shows that you are using WinSCP 5.17.9, not 6.3.7.
- steph_og
- 6
- Thailand
Thanks for your response. I appreciate it. I have upgraded already but not sure why the logs still shows that version? I have also generated a new PuTTY using the newest version but still have the same error as below:
I am just a newbie trying to support the client and would appreciate any help and insights. thank you!
2025-03-20 14:53:36.854 Connecting to 13.54.5.193 port 22000
. 2025-03-20 14:53:36.854 We claim version: SSH-2.0-WinSCP_release_5.17.9
. 2025-03-20 14:53:36.870 Remote version: SSH-2.0-AWS_SFTP_1.1
. 2025-03-20 14:53:36.870 Using SSH protocol version 2
. 2025-03-20 14:53:36.870 Have a known host key of type rsa2
. 2025-03-20 14:53:36.886 Couldn't agree a host key algorithm (available: rsa-sha2-512,rsa-sha2-256)
. 2025-03-20 14:53:36.886 Attempt to close connection due to fatal exception:
* 2025-03-20 14:53:36.886 Couldn't agree a host key algorithm (available: rsa-sha2-512,rsa-sha2-256)
. 2025-03-20 14:53:36.886 Closing connection.-
Site Admin -
@steph_og: You probably have more copies of WinSCP on the machine. Possibly one installed and other just a copy of a binary (or portable package). You have upgraded the installed copy, but you are actually using other copy. How are you starting WinSCP?
Hi @martin , just a normal startup from the Menu for WinSCP. Can I also check if you have premium support for these types of issue? where can I connect and contact you for this?
Thanks.
Thanks.
Site Admin -
- 43,195
- Prague, Czechia
What is "normal startup from the Menu"? Do you mean Windows "Start" menu? Did you check where does the menu shortcut point to? (right-click "WinSCP" menu entry and select "Open file location")
Did you verify that the installer is installing the new version to the same location? You can see the target path here:
https://winscp.net/eng/docs/ui_installer_ready
- steph_og
- 6
- Thailand
Hi @martin,
Here is the location from the Start Menu:
Here is from the Desktop Shortcut:
They point me to the same screen and application
and the installer says here:
Should I just upgrade to 6.3.7?
Please feel free to reach out where I can contact you
Thanks.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs
C:\Program Files (x86)\WinSCP
This PC > Windows (C:) > Program Files (x86) > WinSCP
Thanks.
Site Admin -
What do you mean by "installer says here"? I do not think that installer says "This PC" anywhere. Can you post a screenshot?
- steph_og
- 6
- Thailand
Site Admin -
Ok, so you have 6.3.7 installed. And you obviously can run it (as earlier screenshots show). So how did you obtain the log from 5.17.9? You must have run it another way that time.
- steph_og
- 6
- Thailand
We are doing the transfer by batch file program and here is how it looks like. (attachment 1)
What i do is to just replace the host key from the new connection in winscp when generating a new URL Code session.
One thing I noticed in the new version is it has this extra data in the connection string which we don't have in the other server which I have done the configuration successfully without that error in the logfile. (attachment 2)
Site Admin -
@steph_og: You've never mentioned "batch file" so far. You've kept posting GUI screenshots only.
So does your batch file run
C:\Program Files (x86)\WinSCP\WinSCP.com? I guess it does not. If you believe it does, please post complete session logs both from batch and the GUI.
LavanyaWST
Couldn't agree a key exchange algorithm
WinSCP Version : 6.5.5Couldn't agree a key exchange algorithm (available:
curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2
-nistp384,ecdh-sha2-nistp256,kex-strict-s-v00@openssh.com)
Site Admin -
- 43,195
- Prague, Czechia
Re: Couldn't agree a key exchange algorithm
@LavanyaWST: Please attach a full session log file showing the problem (using the latest version of WinSCP).
