WebDAV connection fails
wsteen
I have a site that I can connect to via Windows Explorer but the same site when trying to open via WinSCP is failing. However when a connection to the same site via Explorer is open (it remains so for about a minute each time) the connection can be made by WinSCP without problems as well. In spite of what the second topic says I have the same problems with Cyberduck. The log shows a scenario in which I try to connect via WinSCP and then also connect via Explorer during the retries after which the connection is made.
Related topics:
WebDAV authentication (Windows) not working
WebDAV connection fails with WinSCP but works with Cyberduck
. 2022-08-31 13:28:52.965 --------------------------------------------------------------------------
. 2022-08-31 13:28:52.965 Session name: UserName@webdav.website.com (Ad-Hoc site)
. 2022-08-31 13:28:52.965 Host name: webdav.website.com (Port: 443)
. 2022-08-31 13:28:52.965 User name: UserName (Password: Yes, Key file: No, Passphrase: No)
. 2022-08-31 13:28:52.965 Transfer Protocol: WebDAV
. 2022-08-31 13:28:52.965 Proxy: HTTP
. 2022-08-31 13:28:52.966 HostName: proxy.somewhere.com (Port: 9480); Username: ; Passwd: No
. 2022-08-31 13:28:52.966 HTTPS: Yes [Client certificate: No]
. 2022-08-31 13:28:52.966 WebDAV: Tolerate non-encoded: No
. 2022-08-31 13:28:52.966 TLS/SSL versions: TLSv1.0-TLSv1.3
. 2022-08-31 13:28:52.966 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2022-08-31 13:28:52.966 Cache directory changes: Yes, Permanent: Yes
. 2022-08-31 13:28:52.966 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2022-08-31 13:28:52.966 DST mode: Unix
. 2022-08-31 13:28:52.966 Compression: No
. 2022-08-31 13:28:52.966 --------------------------------------------------------------------------
. 2022-08-31 13:28:53.047 HTTP session to https://webdav.website.com:443 begins.
. 2022-08-31 13:28:53.047 ssl: SNI enabled by default.
. 2022-08-31 13:28:53.048 auth: Create for WWW-Authenticate
. 2022-08-31 13:28:53.048 Sending request headers:
. 2022-08-31 13:28:53.048 OPTIONS / HTTP/1.1
. 2022-08-31 13:28:53.048 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:28:53.048 Connection: TE
. 2022-08-31 13:28:53.048 TE: trailers
. 2022-08-31 13:28:53.048 Host: webdav.website.com
. 2022-08-31 13:28:53.048 Sending request-line and headers:
. 2022-08-31 13:28:53.048 Doing DNS lookup on proxy.somewhere.com...
. 2022-08-31 13:28:53.117 req: Connecting to 999.99.99.999:9480
. 2022-08-31 13:28:53.254 auth: Create for Proxy-Authenticate
. 2022-08-31 13:28:53.255 Sending request headers:
. 2022-08-31 13:28:53.255 CONNECT webdav.website.com:443 HTTP/1.1
. 2022-08-31 13:28:53.255 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:28:53.255 Connection: TE
. 2022-08-31 13:28:53.255 TE: trailers
. 2022-08-31 13:28:53.255 Host: webdav.website.com
. 2022-08-31 13:28:53.255 Sending request-line and headers:
. 2022-08-31 13:28:53.255 Request sent; retry is 0.
. 2022-08-31 13:28:53.392 [status-line] < HTTP/1.1 200 Connection Established
. 2022-08-31 13:28:53.392 Header Name: [proxy-agent], Value: [Zscaler/6.1]
. 2022-08-31 13:28:53.393 End of headers.
. 2022-08-31 13:28:53.418 auth: Post-send (#0), code is 200 (want 407), Proxy-Authenticate is (none)
. 2022-08-31 13:28:53.418 Request ends, status 200 class 2xx, error line:
. 2022-08-31 13:28:53.418 200 Connection Established
. 2022-08-31 13:28:53.418 Request ends.
. 2022-08-31 13:28:53.418 Doing SSL negotiation.
. 2022-08-31 13:28:54.069 Identity match for 'webdav.website.com': good
. 2022-08-31 13:28:54.070 Verifying certificate for "*.website.com" with fingerprint b9:12:55:29:da:a3:ba:f3:3c:6b:c1:c4:6a:3a:07:a0:03:3b:5c:db:fa:5f:60:78:af:46:f3:af:4b:64:01:ec and 08 failures
. 2022-08-31 13:28:54.126 Certificate verified against Windows certificate store
. 2022-08-31 13:28:54.126 Using TLSv1.2, cipher TLSv1.2: ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
. 2022-08-31 13:28:54.126 Request sent; retry is 0.
. 2022-08-31 13:28:54.414 [status-line] < HTTP/1.1 401 Unauthorized
. 2022-08-31 13:28:54.414 Header Name: [date], Value: [Wed, 31 Aug 2022 11:28:54 GMT]
. 2022-08-31 13:28:54.414 Header Name: [content-type], Value: [text/html]
. 2022-08-31 13:28:54.414 Header Name: [content-length], Value: [1293]
. 2022-08-31 13:28:54.414 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:28:54.415 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:28:54.415 Header Name: [www-authenticate], Value: [Negotiate]
. 2022-08-31 13:28:54.415 Header Name: [www-authenticate], Value: [NTLM]
. 2022-08-31 13:28:54.415 End of headers.
. 2022-08-31 13:28:54.443 auth: Post-send (#0), code is 401 (want 401), WWW-Authenticate is Negotiate, NTLM
. 2022-08-31 13:28:54.444 auth: Got challenge (code 401).
. 2022-08-31 13:28:54.444 auth: Got 'Negotiate' challenge.
. 2022-08-31 13:28:54.444 auth: Got 'NTLM' challenge.
. 2022-08-31 13:28:54.444 auth: Trying Negotiate challenge...
. 2022-08-31 13:28:54.444 auth: SSPI challenge.
. 2022-08-31 13:28:54.555 sspi: Created context with SPN 'HTTP/appgw-prd-02.website.com'
. 2022-08-31 13:28:54.556 auth: SSPI challenge [TlRMTVNTUAABAAAAt4II4gAAAAAAAAAAAAAAAAAAAAAKALpHAAAADw==]
. 2022-08-31 13:28:54.556 auth: Accepted Negotiate challenge.
. 2022-08-31 13:28:54.556 auth: Sending 'Negotiate' response.
. 2022-08-31 13:28:54.556 Sending request headers:
. 2022-08-31 13:28:54.556 OPTIONS / HTTP/1.1
. 2022-08-31 13:28:54.556 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:28:54.556 Connection: TE
. 2022-08-31 13:28:54.556 TE: trailers
. 2022-08-31 13:28:54.556 Host: webdav.website.com
. 2022-08-31 13:28:54.556 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
. 2022-08-31 13:28:54.556 Sending request-line and headers:
. 2022-08-31 13:28:54.557 Request sent; retry is 1.
. 2022-08-31 13:28:54.793 [status-line] < HTTP/1.1 401 Unauthorized
. 2022-08-31 13:28:54.793 Header Name: [date], Value: [Wed, 31 Aug 2022 11:28:54 GMT]
. 2022-08-31 13:28:54.793 Header Name: [content-type], Value: [text/html]
. 2022-08-31 13:28:54.793 Header Name: [content-length], Value: [1293]
. 2022-08-31 13:28:54.793 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:28:54.793 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:28:54.793 Header Name: [www-authenticate], Value: [Negotiate TlRMTVNTUAACAAAABgAGADgAAAA1goni2LAmQ6B6tDQAAAAAAAAAAO4A7gA+AAAACgBjRQAAAA9DAEwAQwACAAYAQwBMAEMAAQAcAGMAbABjAC0AYQB6AC0AYwBsAHMALQBwADAAMgAEAC4AYwBvAHIAcAAuAGwAZQBhAHIAbgBpAG4AZwBoAG8AcwB0AGkAbgBnAC4AbgBsAAMATABjAGwAYwAtAGEAegAtAGMAbABzAC0AcAAwADIALgBjAG8AcgBwAC4AbABlAGEAcgBuAGkAbgBnAGgAbwBzAHQAaQBuAGcALgBuAGwABQAuAGMAbwByAHAALgBsAGUAYQByAG4AaQBuAGcAaABvAHMAdABpAG4AZwAuAG4AbAAHAAgAGi3r2Cy92AEAAAAA]
. 2022-08-31 13:28:54.793 Header Name: [www-authenticate], Value: [NTLM]
. 2022-08-31 13:28:54.794 End of headers.
. 2022-08-31 13:28:54.804 auth: Post-send (#1), code is 401 (want 401), WWW-Authenticate is Negotiate TlRMTVNTUAACAAAABgAGADgAAAA1goni2LAmQ6B6tDQAAAAAAAAAAO4A7gA+AAAACgBjRQAAAA9DAEwAQwACAAYAQwBMAEMAAQAcAGMAbABjAC0AYQB6AC0AYwBsAHMALQBwADAAMgAEAC4AYwBvAHIAcAAuAGwAZQBhAHIAbgBpAG4AZwBoAG8AcwB0AGkAbgBnAC4AbgBsAAMATABjAGwAYwAtAGEAegAtAGMAbABzAC0AcAAwADIALgBjAG8AcgBwAC4AbABlAGEAcgBuAGkAbgBnAGgAbwBzAHQAaQBuAGcALgBuAGwABQAuAGMAbwByAHAALgBsAGUAYQByAG4AaQBuAGcAaABvAHMAdABpAG4AZwAuAG4AbAAHAAgAGi3r2Cy92AEAAAAA, NTLM
. 2022-08-31 13:28:54.804 auth: Got challenge (code 401).
. 2022-08-31 13:28:54.804 auth: Got 'Negotiate' challenge.
. 2022-08-31 13:28:54.805 auth: Negotiate opaque parameter 'TlRMTVNTUAACAAAABgAGADgAAAA1goni2LAmQ6B6tDQAAAAAAAAAAO4A7gA+AAAACgBjRQAAAA9DAEwAQwACAAYAQwBMAEMAAQAcAGMAbABjAC0AYQB6AC0AYwBsAHMALQBwADAAMgAEAC4AYwBvAHIAcAAuAGwAZQBhAHIAbgBpAG4AZwBoAG8AcwB0AGkAbgBnAC4AbgBsAAMATABjAGwAYwAtAGEAegAtAGMAbABzAC0AcAAwADIALgBjAG8AcgBwAC4AbABlAGEAcgBuAGkAbgBnAGgAbwBzAHQAaQBuAGcALgBuAGwABQAuAGMAbwByAHAALgBsAGUAYQByAG4AaQBuAGcAaABvAHMAdABpAG4AZwAuAG4AbAAHAAgAGi3r2Cy92AEAAAAA'
. 2022-08-31 13:28:54.805 auth: Got 'NTLM' challenge.
. 2022-08-31 13:28:54.805 auth: Trying Negotiate challenge...
. 2022-08-31 13:28:54.805 auth: SSPI challenge.
. 2022-08-31 13:28:54.805 auth: SSPI challenge [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]
. 2022-08-31 13:28:54.805 auth: Accepted Negotiate challenge.
. 2022-08-31 13:28:54.806 auth: Sending 'Negotiate' response.
. 2022-08-31 13:28:54.806 Sending request headers:
. 2022-08-31 13:28:54.806 OPTIONS / HTTP/1.1
. 2022-08-31 13:28:54.806 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:28:54.806 Connection: TE
. 2022-08-31 13:28:54.806 TE: trailers
. 2022-08-31 13:28:54.806 Host: webdav.website.com
. 2022-08-31 13:28:54.806 Authorization: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
. 2022-08-31 13:28:54.806 Sending request-line and headers:
. 2022-08-31 13:28:54.806 Request sent; retry is 1.
. 2022-08-31 13:28:55.027 [status-line] < HTTP/1.1 401 Unauthorized
. 2022-08-31 13:28:55.027 Header Name: [date], Value: [Wed, 31 Aug 2022 11:28:54 GMT]
. 2022-08-31 13:28:55.027 Header Name: [content-type], Value: [text/html]
. 2022-08-31 13:28:55.027 Header Name: [content-length], Value: [1293]
. 2022-08-31 13:28:55.027 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:28:55.027 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:28:55.028 Header Name: [www-authenticate], Value: [Negotiate]
. 2022-08-31 13:28:55.028 Header Name: [www-authenticate], Value: [NTLM]
. 2022-08-31 13:28:55.028 End of headers.
. 2022-08-31 13:28:55.028 Negotiate challenge failed, will try different challenge
. 2022-08-31 13:28:55.064 auth: Post-send (#2), code is 401 (want 401), WWW-Authenticate is Negotiate, NTLM
. 2022-08-31 13:28:55.064 auth: Got challenge (code 401).
. 2022-08-31 13:28:55.064 auth: No challenges accepted.
. 2022-08-31 13:28:55.064 Request ends, status 401 class 4xx, error line:
. 2022-08-31 13:28:55.064 Could not authenticate to server: ignored Negotiate challenge, ignored NTLM challenge
. 2022-08-31 13:28:55.064 Request ends.
. 2022-08-31 13:28:55.064 auth: Create for WWW-Authenticate
. 2022-08-31 13:28:55.064 Sending request headers:
. 2022-08-31 13:28:55.064 OPTIONS / HTTP/1.1
. 2022-08-31 13:28:55.064 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:28:55.064 Connection: TE
. 2022-08-31 13:28:55.064 TE: trailers
. 2022-08-31 13:28:55.065 Host: webdav.website.com
. 2022-08-31 13:28:55.065 Sending request-line and headers:
. 2022-08-31 13:28:55.065 Request sent; retry is 1.
. 2022-08-31 13:28:55.293 [status-line] < HTTP/1.1 401 Unauthorized
. 2022-08-31 13:28:55.294 Header Name: [date], Value: [Wed, 31 Aug 2022 11:28:55 GMT]
. 2022-08-31 13:28:55.294 Header Name: [content-type], Value: [text/html]
. 2022-08-31 13:28:55.294 Header Name: [content-length], Value: [1293]
. 2022-08-31 13:28:55.294 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:28:55.295 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:28:55.295 Header Name: [www-authenticate], Value: [Negotiate]
. 2022-08-31 13:28:55.295 Header Name: [www-authenticate], Value: [NTLM]
. 2022-08-31 13:28:55.295 End of headers.
==== Repeated block 1/n ====
. 2022-08-31 13:28:55.330 auth: Post-send (#0), code is 401 (want 401), WWW-Authenticate is Negotiate, NTLM
. 2022-08-31 13:28:55.330 auth: Got challenge (code 401).
. 2022-08-31 13:28:55.331 auth: No challenges accepted.
. 2022-08-31 13:28:55.331 Request ends, status 401 class 4xx, error line:
. 2022-08-31 13:28:55.331 Could not authenticate to server: ignored Negotiate challenge, ignored NTLM challenge
. 2022-08-31 13:28:55.331 Request ends.
. 2022-08-31 13:28:55.331 auth: Create for WWW-Authenticate
. 2022-08-31 13:28:55.331 Sending request headers:
. 2022-08-31 13:28:55.331 OPTIONS / HTTP/1.1
. 2022-08-31 13:28:55.331 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:28:55.331 Connection: TE
. 2022-08-31 13:28:55.332 TE: trailers
. 2022-08-31 13:28:55.332 Host: webdav.website.com
. 2022-08-31 13:28:55.332 Sending request-line and headers:
. 2022-08-31 13:28:55.332 Request sent; retry is 1.
. 2022-08-31 13:28:55.536 [status-line] < HTTP/1.1 401 Unauthorized
. 2022-08-31 13:28:55.536 Header Name: [date], Value: [Wed, 31 Aug 2022 11:28:55 GMT]
. 2022-08-31 13:28:55.536 Header Name: [content-type], Value: [text/html]
. 2022-08-31 13:28:55.536 Header Name: [content-length], Value: [1293]
. 2022-08-31 13:28:55.536 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:28:55.536 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:28:55.536 Header Name: [www-authenticate], Value: [Negotiate]
. 2022-08-31 13:28:55.536 Header Name: [www-authenticate], Value: [NTLM]
. 2022-08-31 13:28:55.536 End of headers.
==== /Repeated block 1/n ====
==== Repeated block n/n ====
. 2022-08-31 13:29:09.938 auth: Post-send (#0), code is 401 (want 401), WWW-Authenticate is Negotiate, NTLM
. 2022-08-31 13:29:09.938 auth: Got challenge (code 401).
. 2022-08-31 13:29:09.938 auth: No challenges accepted.
. 2022-08-31 13:29:09.938 Request ends, status 401 class 4xx, error line:
. 2022-08-31 13:29:09.939 Could not authenticate to server: ignored Negotiate challenge, ignored NTLM challenge
. 2022-08-31 13:29:09.939 Request ends.
. 2022-08-31 13:29:09.939 auth: Create for WWW-Authenticate
. 2022-08-31 13:29:09.939 Sending request headers:
. 2022-08-31 13:29:09.939 OPTIONS / HTTP/1.1
. 2022-08-31 13:29:09.939 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:29:09.939 Connection: TE
. 2022-08-31 13:29:09.939 Host: webdav.website.com
. 2022-08-31 13:29:09.939 Sending request-line and headers:
. 2022-08-31 13:29:09.939 Request sent; retry is 1.
. 2022-08-31 13:29:10.162 [status-line] < HTTP/1.1 401 Unauthorized
. 2022-08-31 13:29:10.162 Header Name: [date], Value: [Wed, 31 Aug 2022 11:29:10 GMT]
. 2022-08-31 13:29:10.162 Header Name: [content-type], Value: [text/html]
. 2022-08-31 13:29:10.162 Header Name: [content-length], Value: [1293]
. 2022-08-31 13:29:10.162 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:29:10.162 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:29:10.162 Header Name: [www-authenticate], Value: [Negotiate]
. 2022-08-31 13:29:10.162 Header Name: [www-authenticate], Value: [NTLM]
. 2022-08-31 13:29:10.162 End of headers.
==== /Repeated block n/n ====
. 2022-08-31 13:29:10.201 auth: Post-send (#0), code is 401 (want 401), WWW-Authenticate is Negotiate, NTLM
. 2022-08-31 13:29:10.201 auth: Got challenge (code 401).
. 2022-08-31 13:29:10.201 auth: No challenges accepted.
. 2022-08-31 13:29:10.201 Request ends, status 401 class 4xx, error line:
. 2022-08-31 13:29:10.201 Could not authenticate to server: ignored Negotiate challenge, ignored NTLM challenge
. 2022-08-31 13:29:10.201 Request ends.
. 2022-08-31 13:29:10.201 auth: Create for WWW-Authenticate
. 2022-08-31 13:29:10.201 Sending request headers:
. 2022-08-31 13:29:10.201 OPTIONS / HTTP/1.1
. 2022-08-31 13:29:10.201 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:29:10.202 Connection: TE
. 2022-08-31 13:29:10.202 TE: trailers
. 2022-08-31 13:29:10.202 Host: webdav.website.com
. 2022-08-31 13:29:10.202 Sending request-line and headers:
. 2022-08-31 13:29:10.202 Request sent; retry is 1.
. 2022-08-31 13:29:10.403 [status-line] < HTTP/1.1 200 OK
. 2022-08-31 13:29:10.403 Header Name: [date], Value: [Wed, 31 Aug 2022 11:29:10 GMT]
. 2022-08-31 13:29:10.403 Header Name: [content-length], Value: [0]
. 2022-08-31 13:29:10.403 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:29:10.403 Header Name: [allow], Value: [OPTIONS, TRACE, GET, HEAD, POST, COPY, PROPFIND, DELETE, MOVE, PROPPATCH, MKCOL, LOCK, UNLOCK]
. 2022-08-31 13:29:10.403 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:29:10.403 Header Name: [public], Value: [OPTIONS, TRACE, GET, HEAD, POST, PROPFIND, PROPPATCH, MKCOL, PUT, DELETE, COPY, MOVE, LOCK, UNLOCK]
. 2022-08-31 13:29:10.403 Header Name: [dav], Value: [1,2,3]
. 2022-08-31 13:29:10.403 Header Name: [ms-author-via], Value: [DAV]
. 2022-08-31 13:29:10.403 End of headers.
. 2022-08-31 13:29:10.413 auth: Post-send (#0), code is 200 (want 401), WWW-Authenticate is (none)
. 2022-08-31 13:29:10.413 Request ends, status 200 class 2xx, error line:
. 2022-08-31 13:29:10.413 200 OK
. 2022-08-31 13:29:10.413 Request ends.
. 2022-08-31 13:29:10.413 Server capabilities: 1, 2, 3
. 2022-08-31 13:29:10.415 Doing startup conversation with host.
. 2022-08-31 13:29:10.432 Changing directory to "/".
. 2022-08-31 13:29:10.432 Trying to open directory "/".
. 2022-08-31 13:29:10.432 auth: Create for WWW-Authenticate
> 2022-08-31 13:29:10.432 <?xml version="1.0" encoding="utf-8"?>
> 2022-08-31 13:29:10.432 <propfind xmlns="DAV:"><allprop/></propfind>
. 2022-08-31 13:29:10.432 Sending request headers:
. 2022-08-31 13:29:10.432 PROPFIND / HTTP/1.1
. 2022-08-31 13:29:10.432 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:29:10.432 Connection: TE
. 2022-08-31 13:29:10.432 TE: trailers
. 2022-08-31 13:29:10.432 Host: webdav.website.com
. 2022-08-31 13:29:10.433 Depth: 0
. 2022-08-31 13:29:10.433 Content-Length: 84
. 2022-08-31 13:29:10.433 Content-Type: application/xml
. 2022-08-31 13:29:10.433 Sending request-line and headers:
. 2022-08-31 13:29:10.433 Sending request body:
. 2022-08-31 13:29:10.433 Request sent; retry is 1.
. 2022-08-31 13:29:10.651 [status-line] < HTTP/1.1 207 Multi Status
. 2022-08-31 13:29:10.652 Header Name: [date], Value: [Wed, 31 Aug 2022 11:29:10 GMT]
. 2022-08-31 13:29:10.652 Header Name: [content-type], Value: [text/xml]
. 2022-08-31 13:29:10.652 Header Name: [content-length], Value: [870]
. 2022-08-31 13:29:10.652 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:29:10.652 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:29:10.652 End of headers.
. 2022-08-31 13:29:10.652 auth: Post-send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2022-08-31 13:29:10.652 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://webdav.website.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 16 Mar 2022 11:47:52 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>/</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2022-03-16T11:47:40.488Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2022-08-31 13:29:10.652 Request ends, status 207 class 2xx, error line:
. 2022-08-31 13:29:10.652 207 Multi Status
. 2022-08-31 13:29:10.652 Request ends.
. 2022-08-31 13:29:10.653 Getting current directory name.
. 2022-08-31 13:29:10.695 Cached directory not reloaded.
. 2022-08-31 13:29:10.717 auth: Create for WWW-Authenticate
> 2022-08-31 13:29:10.717 <?xml version="1.0" encoding="utf-8"?>
> 2022-08-31 13:29:10.717 <propfind xmlns="DAV:"><allprop/></propfind>
. 2022-08-31 13:29:10.717 Sending request headers:
. 2022-08-31 13:29:10.717 PROPFIND / HTTP/1.1
. 2022-08-31 13:29:10.717 User-Agent: WinSCP/5.21.1 neon/0.32.1
. 2022-08-31 13:29:10.717 Connection: TE
. 2022-08-31 13:29:10.717 TE: trailers
. 2022-08-31 13:29:10.717 Host: webdav.website.com
. 2022-08-31 13:29:10.717 Depth: 1
. 2022-08-31 13:29:10.717 Content-Length: 84
. 2022-08-31 13:29:10.717 Content-Type: application/xml
. 2022-08-31 13:29:10.717 Sending request-line and headers:
. 2022-08-31 13:29:10.718 Sending request body:
. 2022-08-31 13:29:10.718 Request sent; retry is 1.
. 2022-08-31 13:29:10.932 [status-line] < HTTP/1.1 207 Multi Status
. 2022-08-31 13:29:10.933 Header Name: [date], Value: [Wed, 31 Aug 2022 11:29:10 GMT]
. 2022-08-31 13:29:10.933 Header Name: [content-type], Value: [text/xml]
. 2022-08-31 13:29:10.933 Header Name: [content-length], Value: [1672]
. 2022-08-31 13:29:10.933 Header Name: [connection], Value: [keep-alive]
. 2022-08-31 13:29:10.933 Header Name: [server], Value: [Microsoft-IIS/10.0]
. 2022-08-31 13:29:10.933 End of headers.
. 2022-08-31 13:29:10.933 auth: Post-send (#0), code is 207 (want 401), WWW-Authenticate is (none)
< 2022-08-31 13:29:10.933 <?xml version="1.0" encoding="utf-8"?><D:multistatus xmlns:D="DAV:"><D:response><D:href>https://webdav.website.com/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 16 Mar 2022 11:47:52 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>/</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2022-03-16T11:47:40.488Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response><D:response><D:href>https://webdav.website.com/Export/</D:href><D:propstat><D:status>HTTP/1.1 200 OK</D:status><D:prop><D:getcontenttype/><D:getlastmodified>Wed, 31 Aug 2022 11:11:04 GMT</D:getlastmodified><D:lockdiscovery/><D:ishidden>0</D:ishidden><D:supportedlock><D:lockentry><D:lockscope><D:exclusive/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry><D:lockentry><D:lockscope><D:shared/></D:lockscope><D:locktype><D:write/></D:locktype></D:lockentry></D:supportedlock><D:getetag/><D:displayname>Export</D:displayname><D:getcontentlanguage/><D:getcontentlength>0</D:getcontentlength><D:iscollection>1</D:iscollection><D:creationdate>2022-03-16T11:47:49.994Z</D:creationdate><D:resourcetype><D:collection/></D:resourcetype></D:prop></D:propstat></D:response></D:multistatus>
. 2022-08-31 13:29:10.933 Request ends, status 207 class 2xx, error line:
. 2022-08-31 13:29:10.933 207 Multi Status
. 2022-08-31 13:29:10.933 Request ends.
. 2022-08-31 13:29:10.934 ..;D;0;2022-03-16T11:47:52.000Z;4;"" [0];"" [0];---------;0
. 2022-08-31 13:29:10.934 Export;D;0;2022-08-31T11:11:04.000Z;4;"" [0];"" [0];---------;0
. 2022-08-31 13:29:11.011 Startup conversation with host finished.
. 2022-08-31 13:29:19.115 sess: Destroying session.
. 2022-08-31 13:29:19.115 sess: Closing connection.
. 2022-08-31 13:29:19.116 ssl: Shutdown state: not sent | not received.
. 2022-08-31 13:29:19.116 ssl: Sending closure.
. 2022-08-31 13:29:19.116 sess: Connection closed.
Re: WebDAV connection fails
I do not think that Windows Explorer uses pure WebDAV for the connection. I does some magic to authenticate the local machine to the server. I believe that magic is equivalent of the net use command. That would explain why WinSCP works then too.
wsteen
Alright, thanks for the explanation.
For anyone that is reading along, this is what I did in the end. I download one small file of which I know that it is always there; this "wakes up" the server. After that I use WinSCP to sync the rest.
[Net.ServicePointManager]::SecurityProtocol += [Net.SecurityProtocolType]::Tls11
[Net.ServicePointManager]::SecurityProtocol += [Net.SecurityProtocolType]::Tls12
$(Invoke-WebRequest "https://$($hostName)/$($remotePath)/StatusType.csv" -Credential $credentials -Proxy "http://$($proxyHost):$($proxyPort)" -UseBasicParsing).Content | Out-Null
