Issues with login that requires passphrase and private key
pjones@mdshvac.com
I am having issues connecting using a bat file with passphrase.
This is the bat file:
cd
net use Z: \\SERVER\FOLDER
robocopy z:\ "c:\Export\FOLDER" FILE.csv /mt /z
C:\"Program Files (x86)"\WinSCP\winscp.com /script=C:\FTPScripts\FILEupload.txt
move C:\Export\FOLDER\FILE.csv C:\Export\FOLDER\BAK\
Which uses FILEupload.txt (note, in this case the passphrase is the same as the password)
option batch on
# Connect
open sftp://USERID:PASSWORD1@url.com -privatekey="c:\FTPScripts\FOLDER\file.ppk" -passphrase="PASSWORD1"
# Change remote directory
cd /FOLDER/Inbox
# Upload the file from current working directory C:\Export\FOLDER\
put C:\Export\FOLDER\FILE.csv
# Exit WinSCP
close
When this runs, I get this in the logfile:
23-06-09 09:51:15.096 --------------------------------------------------------------------------
. 2023-06-09 09:51:15.097 WinSCP Version 5.21.8 (Build 13000 2023-04-11) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2023-06-09 09:51:15.097 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2023-06-09 09:51:15.097 Log level: Normal, Logging passwords
. 2023-06-09 09:51:15.097 Local account: DOMAIN\administrator
. 2023-06-09 09:51:15.097 Working directory: C:\FTPScripts
. 2023-06-09 09:51:15.097 Process ID: 9192
. 2023-06-09 09:51:15.103 Ancestor processes: WinSCP, ...
. 2023-06-09 09:51:15.103 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=5.21.8 /consoleinstance=_2436_968 "/script=C:\FTPScripts\FILEupload.txt"
. 2023-06-09 09:51:15.103 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/12/2023, DST End: 11/5/2023
. 2023-06-09 09:51:15.103 Login time: Friday, June 9, 2023 9:51:15 AM
. 2023-06-09 09:51:15.103 --------------------------------------------------------------------------
. 2023-06-09 09:51:15.103 Script: Retrospectively logging previous script records:
> 2023-06-09 09:51:15.103 Script: option batch on
< 2023-06-09 09:51:15.103 Script: batch           on
> 2023-06-09 09:51:15.103 Script: option confirm off
< 2023-06-09 09:51:15.103 Script: confirm         off
> 2023-06-09 09:51:15.103 Script: open sftp://USERID:PASSWORD1@url.com -privatekey="c:\FTPScripts\FOLDER\file.ppk" -passphrase="PASSWORD1"
. 2023-06-09 09:51:15.103 Session name: USERID@url.com (Ad-Hoc site)
. 2023-06-09 09:51:15.103 Host name: url.com (Port: 22)
. 2023-06-09 09:51:15.103 User name: USERID (Password: PASSWORD1, Key file: c:\FTPScripts\FOLDER\file.ppk, Passphrase: PASSWORD1)
. 2023-06-09 09:51:15.103 Tunnel: No
. 2023-06-09 09:51:15.103 Transfer Protocol: SFTP
. 2023-06-09 09:51:15.103 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2023-06-09 09:51:15.103 Disable Nagle: No
. 2023-06-09 09:51:15.103 Proxy: None
. 2023-06-09 09:51:15.103 Send buffer: 262144
. 2023-06-09 09:51:15.103 Compression: No
. 2023-06-09 09:51:15.103 Bypass authentication: No
. 2023-06-09 09:51:15.103 Try agent: Yes; Agent forwarding: No; KI: Yes; GSSAPI: Yes
. 2023-06-09 09:51:15.103 GSSAPI: KEX: No; Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2023-06-09 09:51:15.103 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2023-06-09 09:51:15.103 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2023-06-09 09:51:15.103 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2023-06-09 09:51:15.103 Simple channel: Yes
. 2023-06-09 09:51:15.103 Return code variable: Autodetect; Lookup user groups: Auto
. 2023-06-09 09:51:15.103 Shell: default
. 2023-06-09 09:51:15.103 EOL: LF, UTF: Auto
. 2023-06-09 09:51:15.103 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2023-06-09 09:51:15.103 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2023-06-09 09:51:15.103 SFTP Bugs: Auto,Auto
. 2023-06-09 09:51:15.103 SFTP Server: default
. 2023-06-09 09:51:15.103 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2023-06-09 09:51:15.103 Cache directory changes: Yes, Permanent: Yes
. 2023-06-09 09:51:15.103 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2023-06-09 09:51:15.103 DST mode: Unix
< 2023-06-09 09:51:15.103 Script: Searching for host...
. 2023-06-09 09:51:15.104 Looking up host "url.com" for SSH connection
. 2023-06-09 09:51:15.115 Connecting to 146.88.111.36 port 22
. 2023-06-09 09:51:15.137 Connected to 146.88.111.36
< 2023-06-09 09:51:15.138 Script: Connecting to host...
. 2023-06-09 09:51:15.138 We claim version: SSH-2.0-WinSCP_release_5.21.8
. 2023-06-09 09:51:15.138 Connected to 146.88.111.36
. 2023-06-09 09:51:15.160 Remote version: SSH-2.0-Unknown_1.0.0
. 2023-06-09 09:51:15.160 Using SSH protocol version 2
. 2023-06-09 09:51:15.162 Have a known host key of type rsa2
. 2023-06-09 09:51:15.162 Doing Diffie-Hellman group exchange
. 2023-06-09 09:51:15.266 Doing Diffie-Hellman key exchange using 4096-bit modulus and hash SHA-256 with a server-supplied group
. 2023-06-09 09:51:18.671 Server also has ssh-dss host key, but we don't know it
. 2023-06-09 09:51:18.671 Host key fingerprint is:
. 2023-06-09 09:51:18.671 ssh-rsa 2048 SHA256:v5UQK02bz7ExxJmVymsV7dU3b7togL0X2NJo11YzfbE
< 2023-06-09 09:51:18.671 Script: Authenticating...
. 2023-06-09 09:51:18.672 Host key matches cached key
. 2023-06-09 09:51:18.672 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] outbound encryption
. 2023-06-09 09:51:18.672 Initialised HMAC-SHA-256 outbound MAC algorithm
. 2023-06-09 09:51:18.672 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] inbound encryption
. 2023-06-09 09:51:18.672 Initialised HMAC-SHA-256 inbound MAC algorithm
. 2023-06-09 09:51:18.695 Reading key file "c:\FTPScripts\FOLDER\file.ppk"
! 2023-06-09 09:51:18.697 Using username "USERID".
< 2023-06-09 09:51:18.697 Script: Using username "USERID".
. 2023-06-09 09:51:18.719 Server offered these authentication methods: password,publickey
. 2023-06-09 09:51:18.719 Offered public key
. 2023-06-09 09:51:18.741 Offer of public key accepted
! 2023-06-09 09:51:18.741 Authenticating with public key "imported-openssh-key"
< 2023-06-09 09:51:18.741 Script: Authenticating with public key "imported-openssh-key".
. 2023-06-09 09:51:18.741 Prompt (passphrase, "SSH key passphrase", <no instructions>, "Passphrase for key "imported-openssh-key": ")
. 2023-06-09 09:51:18.741 Using configured passphrase.
. 2023-06-09 09:51:18.834 Sent public key signature
! 2023-06-09 09:51:18.856 Further authentication required
< 2023-06-09 09:51:18.856 Script: Further authentication required
. 2023-06-09 09:51:18.857 Further authentication required
. 2023-06-09 09:51:18.857 Server offered these authentication methods: password
. 2023-06-09 09:51:18.857 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2023-06-09 09:51:18.857 Using stored password.
< 2023-06-09 09:51:18.857 Script: Authenticating with pre-entered password.
. 2023-06-09 09:51:18.857 Sent password
. 2023-06-09 09:51:18.884 Password authentication failed
! 2023-06-09 09:51:18.884 Access denied
< 2023-06-09 09:51:18.884 Script: Access denied.
. 2023-06-09 09:51:18.885 Server offered these authentication methods:
. 2023-06-09 09:51:18.885 No supported authentication methods available (server sent: )
. 2023-06-09 09:51:18.885 Attempt to close connection due to fatal exception:
* 2023-06-09 09:51:18.885 No supported authentication methods available (server sent: )
. 2023-06-09 09:51:18.885 Closing connection.
< 2023-06-09 09:51:18.885 Script: No supported authentication methods available (server sent: )
< 2023-06-09 09:51:18.885 Authentication log (see session log for details):
< 2023-06-09 09:51:18.886 Using username "USERID".
< 2023-06-09 09:51:18.886 Authenticating with public key "imported-openssh-key".
< 2023-06-09 09:51:18.886 Further authentication required
< 2023-06-09 09:51:18.886 Access denied.
< 2023-06-09 09:51:18.886 Authentication failed.
Re: Issues with login that requires passphrase and private key
Can you authenticate anyhow? In WinSCP GUI? In any other SFTP client? If you can, post its log file.
