Task Scheduler Server 2019
                Hi I am trying to automate an upload of 2 csv files that get updated to a remote server from my application server. The remote server connection is using SSH key which I have setup correctly, I have created a batch file:
When I schedule this batch file, I can't get it to run – I'm assuming that the
In task scheduler, I see a (0x2331) code in Last Run Result
Any suggestions? thanks!
        open sftp://xxxxxxxxxxx@sftp.cmh.xxxxeapp.com/ -hostkey="ssh-rsa 2048 p3J5wTubReewshJFWI7XqiGb480UsJlh2HdgfhgehjJKDk211" -privatekey="C:\ftp\wsftp_private.ppk" -passphrase="houseoflove" lcd "C:\Program Files\xxxMaker\xxxxx Server\Data\Documents\bridge" cd /files put * exit # Execute the script using a command like: # "C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\writable\path\to\log\WinSCP.log" /ini=nul /script="C:\path\to\script\script.txt"
# is commented out which might be the reason its not working.
