Script for put command with file extension
drlachlansmith
NSW
Hi, I try to use the put command to specific file extension (*.zip), it never work. Can you help with that please (the script as below)?
put   "C:\Users\Lachlan Smith\Desktop\syntest home"   "/syn2 soure "
Re: Script for put command with file extension
So what did you try? What is "/syn2 soure "?
The code should be as simple as:
put   "C:\Users\Lachlan Smith\Desktop\syntest home\*.zip" "/target/path/"
drlachlansmith
NSW
*.zip not working
Hi, Thanks very much for the reply, I tried the *.zip, it did not, did you try that from your side?
(also to delete the file in the source folder) when using the put function, if you can help with that.
Really appreciate
Re: *.zip not working
drlachlansmith
NSW
-delete, -latest, and *.extension working now
the code in the script should be in this way:
open ftp://username:password@ip/
lcd "C:\local"
cd "\target"
put -delete "*.txt"
(you can change the -delete to any others like -latest also change the extension to the file needed)
Re: -delete, -latest, and *.extension working now
That also works, but it is equivalent to:
put -delete "C:\local\*.txt" "/target/"
(as I have suggested above).
Note that the remote path needs to use forward slashes. With your backslash the results are unpredictable.
