Scripting a daily 100+ GB upload and keep getting Network errors and timeouts
Scripting a 100+ GB upload and keep getting Network error: Software caused connection abort, timeouts, and taking a very long time.
It either retries or sometimes freezes and I have to break out and try again. It does resume where it left off, but can't seem to get it to complete. Any help would be appreciated.
.bat file
.txt file
uploadPRM.log is full of these messages
.bat file
rem "C:\Program Files\7-Zip\7z.exe" a "D:\ONEDRIVE\PRM_BACKUP\%DATE:~7,2%.%DATE:~4,2%.%DATE:~-4% Backup".zip D:\ONEDRIVE\PRM_Backup\*.bak move "D:\OneDrive\PRM_Backup\*.zip" "D:\OneDrive\PRM_Backup\temp\" "C:\Program Files (x86)\WinSCP\winscp.com" /script="C:\Program Files (x86)\WinSCP\Upload.txt" /log="C:\temp\UploadPRM.log" if %ERRORLEVEL% neq 0 goto error echo Upload succeeded, moving local files move "D:\OneDrive\PRM_Backup\Temp\*.zip" "D:\OneDrive\PRM_Backup\Archive" move "D:\OneDrive\PRM_Backup\Temp\*.bak" "D:\OneDrive\PRM_Backup\Archive" forfiles /p "D:\OneDrive\PRM_Backup\Temp" /s /m *.zip /D -2 /C "cmd /c del @path" exit /b 0 :error echo Upload failed, keeping local files exit /b 1
;WinSCP script to zip files and upload to SFTP server ; Save this with .txt extension and run with WinSCP.com option batch abort option confirm off ; Connect to SFTP server open sftp://username:password@sftp.domain.com -rawsettings SendBuf=0 bin ; Upload zip file put "D:\ONEDRIVE\PRM_BACKUP\temp\*.zip" ; Close connection close exit
. 2025-04-04 12:20:42.526 There are 56672 bytes remaining in the send buffer . 2025-04-04 12:20:42.526 There are 56672 bytes remaining in the send buffer, need to send at least another 23904 bytes . 2025-04-04 12:20:42.526 Detected network event . 2025-04-04 12:20:42.526 There are 56672 bytes remaining in the send buffer . 2025-04-04 12:20:42.526 There are 56672 bytes remaining in the send buffer, need to send at least another 23904 bytes . 2025-04-04 12:20:42.526 Received 26 bytes . 2025-04-04 12:20:42.526 Read 4 bytes (22 pending) . 2025-04-04 12:20:42.526 Read 22 bytes (0 pending) < 2025-04-04 12:20:42.526 Type: SSH_FXP_STATUS, Size: 22, Number: 7182854 < 2025-04-04 12:20:42.526 Status code: 0 . 2025-04-04 12:20:42.542 Detected network event . 2025-04-04 12:20:42.542 There are 56672 bytes remaining in the send buffer . 2025-04-04 12:20:42.542 There are 56672 bytes remaining in the send buffer, need to send at least another 23904 bytes . 2025-04-04 12:20:42.542 Received 26 bytes . 2025-04-04 12:20:42.542 Read 4 bytes (22 pending) . 2025-04-04 12:20:42.543 Read 22 bytes (0 pending)
