Getting error "Host is not communicating for more than 15 seconds. Still Waiting..."
We are unable to connect to SFTP server available in our application, since the time WinSCP tool got updated to 6.5.1 version.
Moreover, the connection is not closed in this case. Instead, it tries to reconnect and it completely queues up the user-connection requests, due to which all threads/sessions gets exhausted and it ultimately prevents all the users from connecting to that SFTP server.
However, we are able to successfully connect to the same SFTP hostname using FileZilla tool.
Way to reproduce:
  1. Open a WinSCP session and try login to SFTP hostname.
  2. The session runs into a timeout.
  3. WinSCP unsuccessfully attempts to auto-connect to the hostname despite of timeout error.
Our expectation:
  1. To be able to connect to SFTP server of our application through upcoming version of WinSCP, without timeout or any other error.
  2. In case of Timeout error, the session should be automatically closed and WinSCP shouldn't retry to connect to that hostname.
Version in which this issue is seen: 6.5.1
Please find attached the snapshot of the error attached to this ticket.
Re: Getting error "Host is not communicating for more than 15 seconds. Still Waiting..."
Please attach a full session log file showing the problem (using the latest version of WinSCP) and well as log from the previous version of WinSCP that still works with your server.
Hi Martin, thanks for the reply. As mentioned by you previously, please find the attached log.
Note: This log was generated when the user tried to login with the 6.5.1 version and faced the connection issue. We couldn't fetch the logs for successful connection as this issue is experienced by our business user-clients with higher versions, and they have either using older WinSCP versions or have switched to FileZilla.
Thanks for the log. Though I do not see any "Host is not communicating..." error in the log.
I can see this though:
Host " dex.eisai.com" does not exist.
Which I believe comes from the leading space in the host name.
Hi Martin,
Sorry for the delay, as we were dependent on one of our client users to face this issue, since we couldn't replicate it fearing any production level issue.
Today one of our client user faced this issue and she has shared the logs with us. Please find that log attached to this message.
Regards,
Prath
Thanks. I'll look into it.
There seems to be some problem/incompatibility with the NTRU Prime / Curve25519 hybrid key exchange newly supported by WinSCP. I cannot tell atm moment, if the problem is on WinSCP or server's side. I can see the same problem when trying to connect to the server using PuTTY though.
As a workaround, you can deprioritize the NTRU Prime / Curve25519 hybrid kex in WinSCP. Then you should be able to connect.
https://winscp.net/eng/docs/ui_login_kex
Hi Martin,
Once again thanks for suggestion. However, could you please implement the solution for the same in the upcoming release?
Regards
@Guest: Can you please clarify what solution do you mean?
Can you please implement following things in the coming release?
  1. Our clients have faced issues in connecting to our SFTP server via WinSCP's recent version. They are able to connect either via version 5.21.3 or lower, or through any other third-party tool. Since the users were able to connect in the older versions, I believe there might be something changed which disturbed the compatibility of our SFTP server with the higher versions of WinSCP. So could you please try to get this fixed in upcoming release?
  2. Just in case if the above scenario isn't achievable, then could you please ensure that if the user receives "Host is not communicating for more than 15 seconds. Still Waiting..." error, then the session should be immediately closed without retrying it? I am requesting for this because in our application WinSCP retries to connect repeatedly, thus it eventually exhausts all the threads of our application, thus causing application inconvenience.
Yes, I am the same person as above. And we did test the KEX suggestion with one of our client. However, that client was still unable to login to the server
Please double check with them. I'm able to get past KEX stage of the connection to dex.eisai.com, when I configure KEX preferences as described above.
If you are not, please send me a session log file showing that.
