Wrong characters in filenames with accents when transferring from french Windows to Linux using Wi
cedric974
Reunion
I'm using WinSCP on a Windows 11 (French locale) computer. When I transfer files whose names contain accented characters (é, è, à, ç, …) to a Linux server (which uses UTF-8), the filenames end up with weird or corrupted characters instead of the accents.
The Linux filesystem itself is configured in UTF-8 and works fine. If I connect via SSH (PuTTY) and list the files, I see ? or garbled characters in place of the accents.
I don't want to change the Linux encoding (it must stay in UTF-8). I only want WinSCP to correctly handle the filename encoding when uploading from Windows.
How can I configure WinSCP to do this?
Thanks a lot!
Re: Wrong characters in filenames with accents when transferring from french Windows to Linux using Wi
zxmon21
Sweden
I see the same issue with German Umlauts. I'm attaching a screenshot of an ls of the same directory with WinSCP 7.5.3 build 16364 (left) and PuTTY 0.83 (right).
The problematic directories were created from WinSCP with recent versions. They look right in WinSCP, but WinSCP can't copy files to them from local. These folders look wrong in PuTTY, Qfile client on mobile and QNAP web interface.
Older folders look right in QNAP web interface, PuTTY, Qfile client on mobile, but wrong on recent WinSCP.
Linux [xxxx] 5.10.60-qnap #1 SMP Tue Jul 15 03:59:56 CST 2025 x86_64 GNU/Linux
zxmon21
Sweden
Here I'm createing one folder with umlaut, and copy a file from local to that folder. Fails with error.
Here I'm createing one folder WITHOU umlaut, and copy a file from local to that folder. Works fine.
@zxmon21: Thanks for all the details.
This is the problem:
. 2025-09-26 09:17:45.401 Listing directory "/share/CACHEDEV5_DATA/Multimedia/Audiobooks Deutsch".
> 2025-09-26 09:17:45.401 Type: SSH_FXP_OPENDIR, Size: 60, Number: 779
< 2025-09-26 09:17:45.433 Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> 2025-09-26 09:17:45.433 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2025-09-26 09:17:45.433 Type: SSH_FXP_NAME, Size: 12700, Number: 1036
> 2025-09-26 09:17:45.433 Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< 2025-09-26 09:17:45.555 Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< 2025-09-26 09:17:45.555 Status code: 1
. 2025-09-26 09:17:45.555 Strings received in non-UTF-8 encoding in a previous packet, will not use UTF-8 anymore
There's probably some broken filename in the Audiobooks Deutsch folder. If you post log with logging level set to Debug 2, I can look further.
In any case, you can override this by setting "UTF-8 encoding for filenames" to On:
https://winscp.net/eng/docs/ui_login_environment
Btw, when you wrote "wrong on recent WinSCP", did you mean that it works with some old version of WinSCP?
zxmon21
Sweden
Excellent, thanks for pointing that out. I changed from UTF-8 AUTO to UTF-8 ON in the site settings. I had to delete some broken-looking folder names using command line, but now WinSCP is working again, and the folder looks like it should.
Regarding "recent" version: I did notice the problem occurring only recently (i.e. I was using a recent WinSCP). I haven't compared to see if it occurs with an older version. So "recent" may be my misinterpretation :)
