Transfer files from remote folder with "mv" command I can't overwrite
mcasper
I am using a bat file to call winscp.exe using /script below.
My script contains the command mv that move files from one remote folder (/BOLLE/temp_000001/) to another remote folder (/BOLLE/) on the same server.
When mv command transfer the files from one to second remote folder and in the destination file/s already exist in which case the equiv source files are not moved.
Is there any way when using the mv command, or other command, to force the target files to always be overwritten so the source files are always "moved"?
V6.5.3 portable SO Windows
option batch continue
option reconnecttime 60
option failonnomatch off
open ftp://xxxxxxx
lcd \xxxxxx\txx
cd /IN
rmdir temp_000001
mkdir temp_000001
cd temp_000001
synchronize remote -filemask="*.ZIP; *.INI|*/" -transfer=binary -delete=off
cd /BOLLE
mv /BOLLE/temp_000001/*.* /BOLLE/
FTP folder tree details:
/IN
/BOLLE
/BOLLE/temp_000001
Thank you, regards
Re: Transfer files from remote folder with "mv" command i can't overwrite
It's not possible.
I have added this request to the tracker:
Issue 2401 – Allow mv command to overwrite target files
You can vote for it there.
Meanwhile, you can:
  • Delete the files from the target folder, if you know their names, or if you can delete all files.
  • Use WinSCP .NET assembly (instead of scripting) to iterate sources files and check their existence in the target folder, deleting and moving as needed.
    https://winscp.net/eng/docs/library
mcasper
Thank you very much, I voted for it.
For now, I don't have the necessary skills to use the .NET version. :-(
Thank you for your effort.
