Move files dropped on an FTP to a local folder without deleting the FTP folders.
anton35
Rennes
I would like to retrieve files deposited from the separate folders of a SFTP and then delete them but keeping the tree (different access rights depending on the users).
I used session.GetFiles with transferOptions.FileMask but I can not get what I want with it.
Depending on the settings either there is an error in the script or there is no error but nothing has been moved:
// Download files
TransferOptions TransferOptions = new TransferOptions();
TransferOptions.TransferMode = TransferMode.Binary;
TransferOptions.FileMask = "*.zip";
TransferOperationResult transferResult = session.GetFiles(
   "/*", @Dts.Variables["$Project::PROP_FilePath"].Value.ToString(), true, TransferOptions);
https://winscp.net/eng/docs/file_mask
I have also tried using session.QueryReceived to override errors (folders are protected and can not be deleted).
But I can not even integrate it into the script without a compilation error (I'm not a developer and I just started SSIS :)).
Recursively download directory tree with custom error handling
Can someone help me?
Thanks in advance.
PS: excuse my English, I'm French :)
anton35
Rennes
I did not start from these models:
I do not know where the logs are, I captured the execution result instead (attachment).
The complete copy of my code:
using System;
using System.Data;
using Microsoft.SqlServer.Dts.Runtime;
using Microsoft.SqlServer.Dts.Tasks.ScriptTask;
using System.Windows.Forms;
using WinSCP;
namespace ST_0211b76178e849199217ecc2d4ccaa07
    [SSISScriptTaskEntryPoint]
    public partial class ScriptMain : VSTARTScriptObjectModelBase
        public void Main()
                Protocol = Protocol.Ftp,
                FtpSecure = FtpSecure.Explicit,
                HostName = Dts.Variables["$Project::PROP_FTP_HostName"].Value.ToString(),
                UserName = Dts.Variables["$Project::PROP_FTP_UserName"].Value.ToString(),
                Password = Dts.Variables["$Project::PROP_FTP_Password"].Value.ToString(),
                TlsHostCertificateFingerprint = Dts.Variables["$Project::PROP_FTP_Fingerprint"].Value.ToString()
            try
                    // As WinSCP .NET assembly has to be stored in GAC to be used with SSIS,
                    // you need to set path to WinSCP.exe explicitly, if using non-default location.
                    session.ExecutablePath = @Dts.Variables["$Project::PROP_CheminWinSCP"].Value.ToString();
                    //session.QueryReceived += (sender, e) =>
                    //    Console.WriteLine("Error: {0}", e);
                    //    e.Continue();
                    // Connect
                    session.Open(sessionOptions);
                    // Download files
                    TransferOptions transferOptions = new TransferOptions();
                    transferOptions.TransferMode = TransferMode.Binary;
                    //transferOptions.FileMask = "*.zip";
                    session.GetFiles(
                        "/*", @Dts.Variables["$Project::PROP_CheminFichiers"].Value.ToString(), true, transferOptions);
                    // Throw on any error
                    transferResult.Check();
                    // Print results
                    bool fireAgain = false;
                    foreach (TransferEventArgs transfer in transferResult.Transfers)
                        Dts.Events.FireInformation(0, null,
                            string.Format("Upload of {0} succeeded", transfer.FileName),
                            null, 0, ref fireAgain);
                Dts.TaskResult = (int)DTSExecResult.Success;
            catch (Exception e)
                Dts.Events.FireError(0, null,
                    string.Format("Error when using WinSCP to upload files: {0}", e),
                    null, 0);
                Dts.TaskResult = (int)DTSExecResult.Failure;
Description: the execution result instead
anton35
Rennes
I tried this code, it works for upload but for the download it becomes complicated: reverse paths does not work (that's my goal).
Am I to understand that the 2 other tracks evoked will not succeed? (1: filemask / 2: error handling).
Thank you for your help.
What are "reverse paths"?
You cannot achieve what you want using file masks.
anton35
Rennes
This code lists local files and directories to upload on FTP and i want to do the opposite.
I tried to adapt the code but I can't :(
Ok for the filemask.
Other possible alternative: to force using error management is feasible?
Thanks a lot
anton35
Rennes
my code that doesn't work :( :
    // Connect
    // Enumerate files and directories to DOWNload
    IEnumerable<FileSystemInfo> fileInfos =
        new DirectoryInfo(remotePath).EnumerateFileSystemInfos(
            "*", SearchOption.AllDirectories);
    foreach (FileSystemInfo fileInfo in fileInfos)
        string localFilePath =
            RemotePath.TranslateRemotePathToLocal(
                fileInfo.FullName, remotePath, localPath);
        if (fileInfo.Attributes.HasFlag(FileAttributes.Directory))
            // Create remote subdirectory, if it does not exist yet
            if (!session.FileExists(localFilePath))
                session.CreateDirectory(localFilePath);
        else
            Console.WriteLine("Moving file {0}...", fileInfo.FullName);
            // DOWNload file and remove original
            session.GetFiles(fileInfo.FullName, localFilePath, true).Check();
anton35
Hello, I would like to go a step further in the process in place by adding the same prefix to all downloaded directories (example: 'COPY _' + folderName)
=> is it possible? and how?
thanks in advance.
Then it would be easier, to iterate the subfolders, like:
$subfolders =
    $session.EnumerateRemoteFiles(
        $remotePath, $Null, [WinSCP.EnumerationOptions]::EnumerateDirectories)
foreach ($subfolder in $subfolders)
    $dest = (Join-Path $localPath ("COPY_" + $subfolder.Name) "*")
    $session.GetFiles($subfolder.FullName + "/*", $dest).Check()
(untested)
anton35
Rennes
I was able to make the change i wanted, everything works fine :
foreach (RemoteFileInfo fileInfo in fileInfos)
     string destFileName = fileInfo.FullName.Insert(1, "COPY_");
                  destFileName, remotePath, localPath);
It helped me a lot.
Best regards.
