batch upload ftp file with private key
steph07
I try to create script batch. I want to uploading files via sftp with private key.
Host SFTP : 213.190.xx.xxx
User : user01
Use private key : PrivateKey
Task : recover the template_fichier*.xlsx in directory \\id-bi-np\c$\Shared_folder\export_BVA and send to SFTP de BVA
option echo off
option batch on
open sftp://user01@213.190.78.147:990/ -privatekey=C:\Temp\Cle_SSH_BVA\PrivateKey.ppk
option transfert binary
# Change LOCAL directory
lcd "\\id-bi-np\c$\Shared_folder\export_BVA"
# copy an entire folder
put -nopermissions -nopreservetime "outgoing"
error message :
C:\Script\enquete_bva>deploy.bat
echo off
batch on
confirm off
Searching for host...
Network error: Connection to "213.190.78.147" timed out.
Unknown option 'transfert'.
Can help.
Best regards.
Parkendol
