Upload files younger than 2 days
User582
Hi, I want to upload .bak files younger than 2 days to another location. When specifying exact name of file it uploads but when I use filemask, it fails.
open sftp://(destination) -hostkey="ciphers"
lcd (location)
cd (remote location)
put *.bak>2D
Is this line right?
put *.bak>2D
The log returns this, so probably the syntax is wrong, i tried many options but nothing worked.
File or folder '*.bak>2D' does not exist. ("System Error. Code: 123.
. 2021-05-25 09:42:11.751 The filename, directory name, or volume label syntax is incorrect")
* 2021-05-25 09:42:11.751 (EScpSkipFile) File or folder '*.bak>2D' does not exist.
User582
Thanks for reply, this gives me "Script failed".
> 2021-05-25 13:13:28.895 Script: put *.bak -filemask=>2D
. 2021-05-25 13:13:28.895 Script: Failed
> 2021-05-25 13:13:28.895 Script: exit
. 2021-05-25 13:13:28.895 Closing connection.
. 2021-05-25 13:13:28.895 Sending special code: 12
. 2021-05-25 13:13:28.895 Sent EOF message
Could it be because Im sing very old version of WinSCP? (4.3.7) on Windows Web Server 2008
