Converting Windows FTP script to WinSCP SFTP script
This guide explains how to convert existing file transfer script using Windows built-in command line FTP client (ftp.exe) to SFTP script using WinSCP.
You can also use it to convert ftp.exe script to FTP script using WinSCP, in case you want to use some advanced feature that WinSCP offers (such as synchronization).
Converting Command-Line
In your command that runs ftp.exe substitute ftp.exe with winscp.com.
Following table shows how to convert some ftp.exe parameters:
| Parameter | Conversion |
-n |
There is no equivalent. In WinSCP all of hostname, username and password are specified using single command open. See also converting credentials below. |
-i |
WinSCP does not prompt for individual transfers during multi-file transfers, so there’s no conversion needed. |
-d |
Enable session logging using /log=logpath parameter. |
-A |
SFTP servers typically do not allow anonymous login. |
-s:filename |
Use /script=filename parameter, see below. |
host |
While WinSCP also allows specifying hostname on command-line, recommended is to use open host command in the WinSCP script. |
Other parameters can be typically ignored.
For example following command:
ftp.exe -s:script.txt
converts to:
winscp.com /script=script.txt
Setting up Batch Mode
As opposite to ftp.exe, WinSCP by default uses interactive mode, even when script is used. So your WinSCP script should typically start with following commands to enable batch mode and to turn off overwrite confirmations:
option batch abort option confirm off
Read more details about using scripting.
Converting Credentials
The ftp.exe client, when hostname is specified on command line and unless -n parameter is used, needs username and password specified as first commands of the script. With WinSCP it is not recommended to specify hostname on command-line and username and password come as arguments to open command.
For example, command ftp.exe ftp.example.com -s:script.txt, with script.txt starting:
username password ...
converts to command winscp.com /script=script.txt, with script.txt starting:
option batch abort option confirm off open sftp://username:password@sftp.example.com
For option commands, see above.
Converting Commands
append
Use put -append <localhost> [remotefile].
ascii
Use -transfer=ascii switch for all following file transfer commands (put or get).
Example:
ascii put file.txt
converts to:
put -transfer=ascii file.txt
Note that WinSCP also supports ascii command, but its use is deprecated.
bye
Use exit.
binary
Use -transfer=binary switch for all following file transfer commands (put or get).
Example:
binary put file.txt
converts to:
put -transfer=binary file.txt
Note that WinSCP also supports binary command, but its use is deprecated.
cd
Use same syntax in WinSCP script.
close
delete
Use rm command (note that delete alias is also supported).
dir
Use ls command.
WinSCP does not support storing listing to a local file (second parameter of dir command).
disconnect
Use close command.
get
glob
In WinSCP, to escape special characters in file mask, use set pattern.
For example to download file with literal * character use get filewithstar[*].
hash
WinSCP always prints percentual progress of file transfer when run in console. It does not output progress when redirected to a file.
lcd
literal
Where are no literal commands in SFTP protocol. You can execute remote shell commands using call command. With FTP protocol, you can use call command to execute FTP protocol commands.
ls
You can use ls command to list directory contents with full details.
mdelete
Use rm command.
mget
Use get command.
You need to map previous binary or ascii commands to -transfer switch.
WinSCP command get can accept multiple files as its arguments, but the last argument needs to be target path. Use .\ to download to current local working directory (equivalent to mget).
Note that get command never prompts before individual file transfer.
Example:
binary mget index.html about.html
converts to:
get -transfer=binary index.html about.html .\
mkdir
mput
Use put command.
WinSCP command put can accept multiple files as its arguments, but the last argument needs to be target path. Use ./ to download to current remote working directory (equivalent to mput).
Example:
binary mput index.html about.html
converts to:
put -transfer=binary index.html about.html ./
! (exit to local shell)
WinSCP does not support exiting to local shell. You need to exit WinSCP script; execute your local commands from a wrapping batch file; and start a new WinSCP script afterwards.
For more advanced tasks, consider using WinSCP .NET assembly from PowerShell script.
