Converting Windows FTP script to WinSCP SFTP script
This guide explains how to convert existing FTP file transfer script using Windows built-in command-line FTP client (ftp.exe
) to SFTP script using WinSCP.
You can also use it to convert FTP script using ftp.exe
to WinSCP, in case you want to use some advanced feature that WinSCP offers, such as FTP over TLS/SSL, synchronization, passive mode1, parametrized script, timestamped file names, custom directory listing format, UTF-8 support, preserving file timestamp, recursive downloads and uploads, and others.
- Converting Command-Line
- Isolating Script from Graphical Mode
- Converting Credentials
- Converting Commands
- Example
In your command that runs ftp.exe
substitute ftp.exe
with winscp.com
Following table shows how to convert some ftp.exe
parameters:
Parameter | Conversion |
-n |
There is no equivalent. In WinSCP all of hostname, username and password are specified using single command open . See also converting credentials below. |
-i |
WinSCP does not prompt for individual transfers during multi-file transfers, so there’s no conversion needed. |
-d |
Enable session logging using /log=<logfile> parameter. |
-A |
SFTP servers typically do not allow anonymous login. With FTP protocol, use explicit anonymous username and some password if needed (typically in form of email address) with open command. |
-s:filename |
Use /script=filename parameter. Convert the script as documented below. |
host |
While WinSCP also allows specifying hostname on command-line, recommended is to use open host command in the WinSCP script. |
Other parameters can be typically ignored.
For example following command:
ftp.exe -s:script.txt
converts to:
winscp.com /script=script.txt
WinSCP in scripting/console mode shares configuration with graphical mode by default. Particularly when implementing script from scratch, it is recommended to isolate the script from graphical mode configuration to avoid script breaking, when the configuration changes.
For that, add /ini=nul
command-line parameter:
winscp.com /script=script.txt /ini=nul
The ftp.exe
client, when hostname (host
parameter) is specified on command line and unless -n
parameter is used, needs username and password specified as the first lines of the script. With WinSCP it is recommended to specify hostname together with username and password as arguments to open
command.
For example, command ftp.exe ftp.example.com -s:script.txt
, with script.txt
starting:
username password ...
converts to command winscp.com /script=script.txt
, with script.txt
starting:
open sftp://username:password@sftp.example.com/
Replace the sftp://
with the ftp://
, if you keep using the FTP protocol.
Converting Commands
append
Use put -append <localfile> [remotefile]
The -append
switch is supported with the SFTP protocol only.
ascii
Use -transfer=ascii
switch for all following file transfer commands (put
or get
Example:
ascii put file.txt
converts to:
put -transfer=ascii file.txt
Note that WinSCP also supports ascii
command, but its use is deprecated.
bye
Use exit
Note that WinSCP also supports bye
alias.
binary
Use -transfer=binary
or get
Example:
binary put file.txt
converts to:
put -transfer=binary file.txt
Note that WinSCP also supports binary
cd
Use cd
command.
close
Use close
command.
delete
Use rm
command.
Note that WinSCP also supports delete
alias.
dir
Use ls
command.
WinSCP does not support storing listing to a local file (second parameter of dir
command).
Note that WinSCP also supports dir
alias.
disconnect
Alias to close
command.
get
Use get
command.
You need to map previous binary
or ascii
commands to -transfer
switch.
Example:
ascii get index.html
converts to:
get -transfer=ascii index.html
glob
In WinSCP, to escape special characters in filename, use set pattern.
For example to download file with literal *
character, use get filewithstar[*]
hash
WinSCP always prints percentual progress of file transfer when run in console. It does not output progress when redirected to a file.
lcd
Use lcd
command.
literal
There are no textual commands in SFTP protocol. You can execute remote shell commands using call
command.
With FTP protocol, you can use call
command to execute FTP protocol commands.
ls
You can use ls
command to list directory contents with full details.
mdelete
Use rm
command.
mget
Use get
command.
or ascii
switch.
WinSCP command get
can accept multiple files as its arguments, but the last argument needs to be target path. Use .\
to download to current local working directory (equivalent to mget
Note that get
command never prompts before individual file transfer.
Example:
ascii mget *.html *.txt
converts to:
get -transfer=ascii *.html *.txt .\
Note that WinSCP also supports mget
as an alias to get
command.
mkdir
Use mkdir
command.
mput
Use put
command.
or ascii
switch.
WinSCP command put
can accept multiple files as its arguments, but the last argument needs to be target path. Use ./
to upload to current remote working directory (equivalent to mput
Note that put
Example:
ascii mput *.html *.txt
converts to:
put -transfer=ascii *.html *.txt ./
Note that WinSCP also supports mput
as an alias to put
command.
open
Use open
command.
Credentials specified on separate lines of ftp.exe
script (following open
command) need to convert to part of session URL parameter of WinSCP open
command. See converting credentials above. The same applies to username specified using user
command.
Example:
open ftp.example.com username password
or equivalent (when ftp.exe -n
command-line parameter is used):
open ftp.example.com user username password
converts to:
Replace the sftp://
with the ftp://
prompt
put
Use put
command.
or ascii
switch.
Example:
ascii put index.html
converts to:
put -transfer=ascii index.html
pwd
Use pwd
command.
quit
Alias to bye
command.
quote
Alias to literal
command.
recv
Alias to get
command.
Note that WinSCP also supports recv
alias.
rename
Use mv
command.
Note that WinSCP also supports rename
alias.
rmdir
Use rmdir
command.
send
Alias to put
command.
Note that WinSCP also supports send
alias.
type
Command type ascii
is an alias to ascii
command.
Command type binary
is an alias to binary
command.
user
In WinSCP, username is specified as part of session URL parameter of WinSCP open
command.
Example:
converts to:
Replace the sftp://
with the ftp://
verbose
There is no direct equivalent.
You can instead enable session logging using /log=<logfile>
winscp.com /script=script.txt /ini=nul /log=session.log
! (exit to local shell)
WinSCP does not support exiting to local shell. You need to exit WinSCP script; execute your local commands from a wrapping batch file; and start a new WinSCP script afterwards.
For more advanced tasks, consider using WinSCP .NET assembly from PowerShell script.
Example
Command ftp.exe -s:script.txt
with script.txt
prompt open ftp.example.com username password cd /home/user binary mget *.zip close quit
converts to command winscp.com /script=script.txt /ini=nul
with script.txt
open sftp://username:password@sftp.example.com/ cd /home/user get -transfer=binary *.zip close exit
Replace the sftp://
with the ftp://
- WinSCP defaults to passive mode.Back
