Converting PuTTY PSFTP or OpenSSH SFTP script to WinSCP script
This guide explains primarily how to convert existing SFTP file transfer script using PuTTY SFTP client (psftp.exe) to script using WinSCP, in case you want to use some advanced feature that WinSCP offers, such as synchronization, parametrized script, timestamped file names, custom directory listing format and others.
As the PSFTP syntax is based on OpenSSH sftp client,1 you can also use the guide to convert your existing Linux SFTP script to a Windows SFTP script.
- Converting Command-Line
- Isolating Script from Graphical Mode
- Verifying the Host Key
- Converting Commands
- Example
In your command that runs psftp.exe, substitute the psftp.exe with winscp.com.
The following table shows how to convert some psftp.exe parameters:
| Parameter | Conversion |
[user@]host |
Specify the username and the hostname in a session URL in an open command in the script. Example: open sftp://user@host/ |
-b file |
Replace with /script=file. |
-bc |
Use an option echo on command at the beginning of the script. |
-be |
Use an option batch on command at the beginning of the script (to counter the default option batch abort). |
-load sessname |
Import your PuTTY stored session to WinSCP and use an open sessname command in the script. Though this makes the script dependent on GUI configuration (see below). You should better use a Generate Session URL/Code function and use the generated open command in the script. |
-l user |
Specify the username in a session URL in an open command in the script. Example: open sftp://user@example.com/ |
-P port |
Specify the port number in a session URL in an open command in the script. Example: open sftp://example.com:port/ |
-pw passw |
Specify the password in a session URL in an open command in the script. Example: open sftp://user:passw@example.com/ |
-i key |
Specify the private key using -privatekey switch in an open command in the script. Example: open sftp://user@example.com/ -privatekey=key |
-hostkey xxxx...= |
Specify the expected hostkey using -hostkey switch in an open command in the script. WinSCP requires key type and size in the signature. Example: open sftp://user@example.com/ -hostkey="ssh-rsa 2048 xxxxxxxxxxx...=" (assuming 2048-bit RSA host key) See also Verifying the host key section below. |
For example the following PSFTP command-line:
psftp.exe martin@example.com -pw password -hostkey aa:bb:cc:... -b script.txt
converts to:
winscp.com /script=script.txt
with the script.txt containing open command at its beginning:
open sftp://martin:password@example.com/ -hostkey="ssh-rsa 2048 aa:bb:cc:..."
WinSCP in a scripting/console mode shares a configuration with a graphical mode by default. Particularly when implementing the script from scratch, it is recommended to isolate the script from the graphical mode configuration to avoid the script breaking, when the GUI configuration changes.
For that, add an /ini=nul command-line parameter:
winscp.com /script=script.txt /ini=nul
If your psftp.exe command-line does not use -hostkey switch, it means that you rely on PuTTY/PSFTP host key cache in Windows registry. That makes your script non-portable.
With WinSCP it’s recommended to always verify the host key explicitly using -hostkey switch of an open command.
Converting Commands
Many PSFTP commands work in WinSCP without any change.
The differences are described below.
WinSCP requires the script to end with the exit command for the process to close automatically.
cd
Use a cd command with the same argument.
chmod
Use a chmod command with the same arguments.
WinSCP supports octal permissions format only.
close
Use a close command.
del
Use a rm command with the same arguments.
dir
Use a ls command with the same argument.
Note that WinSCP also supports a dir alias.
get
Use a get command with the same arguments.
WinSCP downloads directories recursively by default. So remove a -r switch, if used.
When downloading file(s) to a specific directory, make sure you terminate a target path with a backslash:
get *.txt c:\path\
lcd
Use a lcd command with the same argument.
lpwd
Use a lpwd command.
mget
Use a get command.
The WinSCP command get can accept multiple files as its arguments, but the last argument needs to be a target path. Use .\ to download to the current local working directory (equivalent to the mget).
Example:
mget *.html *.txt
converts to:
get *.html *.txt .\
Note that WinSCP also supports a mget as an alias to the get command.
mkdir
Use a mkdir command with the same argument.
mput
Use a put command.
The WinSCP command put can accept multiple files as its arguments, but the last argument needs to be a target path. Use ./ to upload to the current remote working directory (equivalent to the mput).
Example:
mput *.html *.txt
converts to:
put *.html *.txt ./
Note that WinSCP also supports a mput as an alias to the put command.
mv
Use a mv command with the same arguments.
When moving file(s) to a different directory, make sure you terminate the target path with a slash:
mv *.txt /path/
PSFTP aliases to the mv command, a rename and a ren, convert the same way.
open
Use an open command.
For example the full PSFTP open command:
open user@host 22
converts to:
open sftp://user@host:22/
put
Use put command with the same arguments.
WinSCP uploads directories recursively by default. So remove a -r switch, if used.
When uploading file(s) to a specific directory, make sure you terminate the target path with a slash:
put *.txt /path/
pwd
Use a pwd command.
quit
Use an exit command.
Note that WinSCP also supports bye alias, just as PSFTP.
reget
WinSCP resumes SFTP transfers automatically. To explicitly resume transfer (for example with an FTP protocol), use get -resume.
reput
WinSCP resumes SFTP transfers automatically. To explicitly resume transfer (for example with an FTP protocol), use put -resume.
rmdir
Use a rmdir command with the same arguments.
! (exit to local shell)
WinSCP does not support exiting to a local shell. You need to exit WinSCP script; execute your local commands from a wrapping batch file; and start a new WinSCP script afterwards.
For more advanced tasks, consider using WinSCP .NET assembly from PowerShell script.
Example
A command psftp.exe -b script.txt with script.txt:
open user@example.com cd /home/user mget *.zip close quit
converts to a command winscp.com /script=script.txt /ini=nul with script.txt:
open sftp://user@example.com/ cd /home/user get *.zip close exit
- Both the PSFTP command-line switches and the script commands are subset of OpenSSH
sftpswitches and commands.Back
